Recently i started having a couple of issues with my panel blocks. I noticed it when certain blocks were not showing up in my bom. While investigating i noticed a handful of attributes showing a value as such
MFG \w0.7000;AB
CAT \w0.7000;1769-OW8
ETC.
I noticed that the "\w0.7000" is the width factor. For some reason i cannot figure out how to fix my block. Other than creating a new one.
If i try to modify it through the quick properties or regular properties tab i can not click on it to edit.
Any ideas??
Solved by rhesusminus. Go to Solution.
Seems like your attributes are set to be multi line.
Try to set this to No:
I guess you'll have to edit the symbols with the symbol builder, and then run the block update function for you blocks.
