When I do a TitleBlock update and do a save, the default.wdu file is created in my local roaming directory.
Is it possible to change this location? I thought with most project related files, it looked in the project directory first?????
This is viewed as a user-specific setting rather than a project setting. So it is saved in the user folder and that is the only place that AutoCAD Electrical looks for it. I don't see any way to change this at this time.
Pat Murnen
Don't forget about logging ideas for improvement on the IdeaStation. You may not be the only one who would like this changed and the IdeaStation gives people an opportunity to vote.
Pat
Thanks for this Pat I wasn't aware there was one specifically for AutoCAD Electrical.
Yes, it is fairly new. I think there was an announcement on this site and also on the blog. If you go there to log your idea don't forget to look at the other ideas and vote (by clicking Kudos) for any others that you like.
Pat
