AutoCAD Electrical Forum
.WDP FILE MISSING FROM PROJECT MANAGER UPON CLOSE/REOPEN OF ACADE 2014
2 REPLIES 2
sparky_mike
578 Views, 2 Replies
Does anyone know why my projects keep missing when I close AutoCAD Electrical 2014 and reopen? The .wdp file is located on the server, and was created by another user on a different machine if that matters.
Mike
2 REPLIES 2
rhesusminus
in reply to: sparky_mike
Seems like AutoCAD ELectrical can't write this information to LASTPROJ.FIL
This is the file where the Project Manager get its information about what projects you have loaded and what's the active one.
The file is located in the user folder.
Copy and paste this into the addressbar og windows explorer and press enter:
%appdata%\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\User
You can safely delete this file (if you're able to) and restart AcadE and check if your problem persists.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
sparky_mike
in reply to: rhesusminus
Better late than ever... That did it.
”Boost
