Heres a booger for this early Wed.
I have recently stumbled upon an issue with the project manager missing drawings that I have recently added to the project. After I re-add them, the drawing properties are gone (DD1, DD2, DD3, sect., sub-sect.). I know that I have added these in because right after I do I run the title block update to populate my drawing descriptions that originate from the properties of that drawing, including the filename with ext., so I know I was not accidently in a different drawing.
I do all of my projects like this, and have not seen this. It has happened 4 times that I know of, each instance dropping 3 to 4 drawings. The only change to how I normally do this is that there are multiple users accessing the .wdp file on the server where all of the drawings are located also. It has happened to myself, and another user on a different PC.
Any help on this would be much appreciated.
