AutoCAD Electrical Forum
.wda File Question
5 REPLIES 5
Hedivan
747 Views, 5 Replies
.wda File Question
Is there a default name that can be given to the User Defined Attribute List file (.wda) so the file does not have to have the same name as the project. I want to be able to use the same file for each project without having to rename the file to match the project. Similar to the way the Title block mapping file works (default_wdtitle.wdl).
Is this possible?
5 REPLIES 5
sven_kloeck
in reply to: Hedivan
found in the electrical help:
default.wda
Sven Kloeck
Electrical Network Design
in reply to: sven_kloeck
Can you place the default.wda in a central location so that it is relevant to all network users?
dougmcalexander
Place it in your User folder.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
flyFisher67
Hi All,
I've been trying to use the method described above. It is working just fine on a project by project basis, but I have set up a default.WDA file to use for all projects and saved it on our network under USER but no results. Another post says to save this file at the base project location - where would that be?
Any help would be greatly appreciated.
Mike
Nata_ly
in reply to: flyFisher67
Try to do next:
1. Put default.wdl and default.wda to your network.
2. Find all default.wdl and default.wda on you computer and rename they (ex. default1.wda)
3. Make sure there are no <projectname>.wdl and <projectname>.wda files too
4. Open Options in ACE and choose tab Files line Support File Search Path. Add there your path to the default.wda from network.
5. Repeat the same on all computers in your office to make them use this files from network
This works for sure with default.wdl and I hope could work with default.wda too.
If this files are only for your use - put they into Suport folder or any other folder but add the path.
”Boost
