Are there any other drawing files on your hard drive in the panel folder? There should be quite a number of files that ACE uses to merge onto "dumb" footprints to make them "smart." Look for wd_ptag_addattr_comp.dwg. The wd_ptag.dwg resides in the same folder. In case yours got lost I will attach one.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
