Create your border with mapped attributes for the title block update. Save
it as DWG. Then insert this border into a blank drawing file (use acad.dwt
template). Now click drawing properties and you are editing the WD_M block.
Choose your preferences and save as a template. Each time you start a new
drawing, use this template and you will get your preferences by default.
wrote in message news:5747981@discussion.autodesk.com...
The block is inserted as "invisible" upon drawing creation. Is there a way
to make it "Visible"? Or is there a way to edit the fields in this block
before drawing creation? There are also other blocks associated with this
block. WD_PNLM.dwg, WD_MLRH.dwg, WD_MLRV.dwg & WD_MLRHX.dwg, WD_MLRVX.dwg.
Im am very new at ACADE and just getting started. Basically we are trying
to setup predetermined attributes for a specific job, and need to know whats
the best way to accomplish this?
Thanks for replies in advance!
