Rob,
I was able to insert the symbol without any problems. What version of AcadE
are you using? Did you add it to your icon menu or just Browse to it for
insertion?
Pat Murnen
wrote in message news:5877244@discussion.autodesk.com...
Hello everybody,
When trying to make a custom terminal connector symbol ACE crashes.
The following works:
insert existing connector symbol (for example HT1002)
explode
run Symbol Builder
select exploded symbol and save as wblock
insert newly created custom symbol
all OK
Next:
explode
! edit default value of CAT or MFG
run Symbol Builder
insert custom symbol
Autocad freezes, showing an hourglass.
With othe
r symbols this problem doesn't occur.
With command trace on, this is the last ACE tells:
IN:term_fillin_txtvals
IN:wd_esym_err
I have a screenshot of more of the last commands, if neccessary. I also
attached the faulty symbol.
Does anybody have an idea what might be wrong?
Thanks in advance,
Rob Wilbers
