AutoCAD Electrical General Discussion
Active Contributor
Shaffy
Message 1 of 2 (169 Views)
WD.ENV FILE
169 Views, 1 Replies
05-07-2008 06:28 AM
Hi All,
Can anybody let me know about the wd.env file. How can we open this file and other details. What it consists of and what is its use.
Thanks in advance
Bye n regards,
Shaffy
*Expert Elite*
dougmcalexander
Message 2 of 2 (169 Views)
Re: WD.ENV FILE
05-09-2008 11:52 AM in reply to: Shaffy
The WD.ENV file is located in the AeData folder, parallel to the Proj,
Catalogs, and PLC folders. There is also a Tutorial folder if you have
version 2009. The WD.ENV is an environment variable file that allows you to
specify such things as the default path for inserting a symbol or footprint
using the Browse button on the Insert menu. You can also turn on such
features as an automatic zoom extents, by simply removing the asterisk at
the beginning of that line. You can define a zip utility to use when Acad/E
offers to create a zip backup of your project prior to a project-wide
update. You edit the WD.ENV file with Notepad or Wordpad and simply save as
a text file. See the attached screen shot for examples.
wrote in message news:5924690@discussion.autodesk.com...
Hi All,
Thanks in advance
Bye n regards,
Shaffy
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
