The WD.ENV file is located in the AeData folder, parallel to the Proj,
Catalogs, and PLC folders. There is also a Tutorial folder if you have
version 2009. The WD.ENV is an environment variable file that allows you to
specify such things as the default path for inserting a symbol or footprint
using the Browse button on the Insert menu. You can also turn on such
features as an automatic zoom extents, by simply removing the asterisk at
the beginning of that line. You can define a zip utility to use when Acad/E
offers to create a zip backup of your project prior to a project-wide
update. You edit the WD.ENV file with Notepad or Wordpad and simply save as
a text file. See the attached screen shot for examples.
wrote in message news:5924690@discussion.autodesk.com...
Hi All,
Can anybody let me know about the wd.env file. How can we open this file and
other details. What it consists of and what is its use.
Thanks in advance
Bye n regards,
Shaffy
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
