AutoCAD Electrical General Discussion
cwilkerson2612
Message 1 of 2 (1,818 Views)
wd.env file location
1818 Views, 1 Replies
08-06-2010 11:13 AM
Presently when Autocad Electrical starts up  - it looks for the wd.env file to be on My Documents ( Company Network Drive/Server) and I wolud like to change the location to my hard Drive.
Thanxx,CW
Distinguished Contributor
scottgensemer8984
Message 2 of 2 (1,785 Views)
Re: wd.env file location
08-10-2010 11:50 AM in reply to: cwilkerson2612
I do a similar thing here. We have all the common data (templates, symbols, databases. etc) located on a file server, and I needed to have all users use the same WD.ENV file to point to the right stuff.
What I did is create a setup .BAT file that deletes everything in the My documents AeData folder except the "Proj" and "Tutorial" folders. At the same time, it copies my network WD.ENV file, and a few other default files to "C:\Program Files\Autodesk\Acade 2010\Acade" (Windows XP Pro), which is on the search path already set in Acad-e. Since the WD.ENV file is gone from the My Documents folders, it reads the one in the Program Files area on the hard drive. Part of our standard install procedure is running this config .BAT file on each user's computer. Has the added benefit of an easy upgrade if you modify the network .ENV file. Just re-run the config file and you're all set. I store the network WD.ENV file and the others I copy locally in a special folder on the network the users normally have no access to. I also created several startup .BAT files to load up special WD.ENV fiiles to configure the program for IEC, JIC, or training. (Different paths for each)
I love .BAT files. You can create one to automate just about any file/folder task you need. ('Course I also date from the "Bad Ole DOS Days", so I learned how to use them a lo-o-ong time ago!)
Hope that helps!
Scott
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
