AutoCAD Electrical General Discussion
*Nate Holt \(Autodesk\)
Message 1 of 3 (296 Views)
Vertical Wire Numbers - how to
296 Views, 2 Replies
03-08-2005 03:08 PM
This comes up from time to time. You want wire numbers for vertical wires to come in automatically rotated 90 degrees so that the wire number lays along the wire. To do: 1. Determine the schematic symbol library in use and open drawing "wd_wnv.dwg" in AutoCAD. 2. Rotate the WIRENO attribute 90 degrees (you can use the AcadE "rotate wire number" cmd if you'd like) 3. Save 4. Open drawing "wd_wcv.dwg". Repeat steps 2 and 3. That's it. Wire numbers for new drawings will come in auto-rotated.
*Robert Stein
Message 2 of 3 (296 Views)
Re: Vertical Wire Numbers - how to
03-09-2005 07:15 PM in reply to: *Nate Holt \(Autodesk\)
Great tip Nate. Robert Stein INCAT rstein@incat.com www.incat.com "Nate Holt (Autodesk)" wrote in message news:422e3068_3@newsprd01... > This comes up from time to time. You want wire numbers for vertical wires to > come in automatically rotated 90 degrees so that the wire number lays along > the wire. To do: > > 1. Determine the schematic symbol library in use and open drawing > "wd_wnv.dwg" in AutoCAD. > 2. Rotate the WIRENO attribute 90 degrees (you can use the AcadE "rotate > wire number" cmd if you'd like) > 3. Save > 4. Open drawing "wd_wcv.dwg". Repeat steps 2 and 3. > > That's it. Wire numbers for new drawings will come in auto-rotated. > >
Active Member
taclauss
Message 3 of 3 (243 Views)
08-29-2011 11:39 AM in reply to: *Robert Stein
It would be nice to have a Rotate Wire Number (Rotate Attribute) command located next to the flip and toggle (in-line) icons in the Ribbon.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
