AutoCAD Electrical Forum
Vertical Wire Numbers - how to
6 REPLIES 6
2155 Views, 6 Replies
This comes up from time to time. You want wire numbers for vertical wires to come in automatically rotated 90 degrees so that the wire number lays along the wire. To do: 1. Determine the schematic symbol library in use and open drawing "wd_wnv.dwg" in AutoCAD. 2. Rotate the WIRENO attribute 90 degrees (you can use the AcadE "rotate wire number" cmd if you'd like) 3. Save 4. Open drawing "wd_wcv.dwg". Repeat steps 2 and 3. That's it. Wire numbers for new drawings will come in auto-rotated.
6 REPLIES 6
Great tip Nate. Robert Stein INCAT rstein@incat.com www.incat.com "Nate Holt (Autodesk)" wrote in message news:422e3068_3@newsprd01... > This comes up from time to time. You want wire numbers for vertical wires to > come in automatically rotated 90 degrees so that the wire number lays along > the wire. To do: > > 1. Determine the schematic symbol library in use and open drawing > "wd_wnv.dwg" in AutoCAD. > 2. Rotate the WIRENO attribute 90 degrees (you can use the AcadE "rotate > wire number" cmd if you'd like) > 3. Save > 4. Open drawing "wd_wcv.dwg". Repeat steps 2 and 3. > > That's it. Wire numbers for new drawings will come in auto-rotated. > >
taclauss
It would be nice to have a Rotate Wire Number (Rotate Attribute) command located next to the flip and toggle (in-line) icons in the Ribbon.
mwilsonNFZXC
in reply to: taclauss
Lets face it, it should be able to identify which wire is is vertical or horizontal and select a different symbol.
Currently, if you do vertical 3phase and put 3phase wire numbers in, you can't use the AEALIGN tools, it's expecting them to be horizontal.
Every other package out there does this, and some use the slope of the wire and rotate it automatically.
john.starrKZRKV
Wire color/Gauge labels, follow the wire (horz/vert) why can't the wire numbers, Autodesk?
You should post this in the Idea Station.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
chenj
in reply to: john.starrKZRKV
Hi,Wire numbers can also follow wires(horz/vert), and horizontal wire numbers use WD_ WNH.dwg, vertical line number uses WD_ WNV.dwg (wire number is horizontal by default and can be changed to vertical)
”Boost
