AcadE looks at the orientation of the wires. If you are inserting the
component symbol before wires are inserted, as with point-to-point for
example, you can select the vertical button to force the vertical version of
the symbol.
wrote in message news:5995729@discussion.autodesk.com...
How does AutoCADE know the block to choose when all you do is check the
"Vertical" box in the Icon menu?
I thought that is why the naming convention was, so important and that
AutoCADE simply replaced the "H" with a "V".
Yet that does not seem to be the case, for a few components.
Thanks.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
