AutoCAD Electrical General Discussion
Nicolas.L
Message 1 of 6 (401 Views)
[VBA] How to generate a Point and a "etiquette"
401 Views, 5 Replies
12-06-2012 06:55 AM
I would like to generate a point and an "etiquette" (I don't know the english word for that) in VBA and adding it to my block
I attached a picture showing what I want this is easier :smileywink:
Nicolas
Nata_ly
Message 2 of 6 (390 Views)
Re: [VBA] How to generate a Point and a "etiquette"
12-06-2012 07:30 AM in reply to: Nicolas.L
Maybe 'notes'... I don't use english ACE too.
But it's in 'Home' ribbon, Annotations... circle with an arrow under 'Size'.
Is this you looking for?
rhesusminus
Message 3 of 6 (378 Views)
12-06-2012 11:46 AM in reply to: Nicolas.L
Can you be more specific?
To draw some lines, and add a text to it... that I can help you with in VBA. But.. adding it to the block?
What block? Shold the lines/text be added to the block? Might make some trouble for you....
Trond Hasse Lie
ECAD Consultant
CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Nicolas.L
Message 4 of 6 (358 Views)
12-07-2012 12:08 AM in reply to: rhesusminus
Morning,
Thanks for your answer so, I will try to explain my problem:
I would like to have something like a connection point and a annotation referring to this point in VBA in order to be abler to generate automatically wire between this two points in VBA. If some one have example of kind of project similar I will be grateful.
Nata_ly : I tried "notes" and it is not that, I think this is only for annotation.
rhesusminus : In fact this is not only line I think and text I think, I am looking for an item acting like a wire connection. Don't worry about the block I give you a sample of my code:
Sub Design_1()
'Define the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0
insertionPnt(1) = 0
insertionPnt(2) = 0
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
' Add a circle to the block
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 0
center(1) = 0
center(2) = 0
radius = 1
Set circleObj = blockObj.AddCircle(center, radius)
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "Polyline")
' Define the outside of the dessin_1
Dim Point(14) As Double
Dim poly As AcadPolyline
Point(0) = 0: Point(1) = 0: Point(2) = 0
Point(3) = 80: Point(4) = 0: Point(5) = 0
Point(6) = 80: Point(7) = 60: Point(8) = 0
Point(9) = 0: Point(10) = 60: Point(11) = 0
Point(12) = 0: Point(13) = 0: Point(14) = 0
Set poly = blockObj.AddPolyline(Point)
' Define the attribute definition, Cette partie permet d'ajouter un attribut au bloque
    Dim attributeObj As AcadAttribute
    Dim insertionPnt1(0 To 2) As Double
    Dim height As Double
    Dim mode As Integer
    Dim prompt As String
    Dim tag As String
    Dim value As String
    height = 5
    mode = acAttributeModeNormal
    tag1 = "Part_No"
    prompt1 = "What is the Part No?"
    value1 = "172.168.0.1"
    insertionPnt1(0) = 5#: insertionPnt1(1) = 5: insertionPnt1(2) = 0
' Define the attribute definition, Cette partie permet d'ajouter un attribut au block
    'Dim acadPT As AcadPoint
    'Dim NewPoint(2) As Double
    'NewPoint(0) = 40: NewPoint(1) = 0: NewPoint(2) = 0
' Insert the block MOP
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 150
    insertionPnt(1) = 150
    insertionPnt(2) = 0
' Add The Attribut IP¨to the Block
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt1, insertionPnt1, tag1, value1)
'Ajoute le cercle au block
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock _
    (insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
'Ajoute le rectangle au block
    (insertionPnt, "Polyline", 1#, 1#, 1#, 0)
ZoomAll
MsgBox "Le bloque se trouve " & blockRefObj.ObjectName
End Sub
rhesusminus
Message 5 of 6 (351 Views)
12-07-2012 04:49 AM in reply to: Nicolas.L
So... In your drawing, you want to find all blocks named "CircleBlock", and connect these somehow, with an AEWIRE ?
Trond Hasse Lie
ECAD Consultant
CtrlAltEl
Nicolas.L
Message 6 of 6 (317 Views)
12-09-2012 10:43 PM in reply to: rhesusminus
Morning rhesusminus,
Sorry for my late answer but yes, I think i would like to to find two circle named something like "circle_128" and "circle_3" and connect these .
Maybe with an AEWIRE, i don't realy know the different wires, I am new on AutocadElectrical.
Regards
Nicolas
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
