AutoCAD Electrical Forum
[VBA] Adding a drawing to a project folder
2 REPLIES 2
Nicolas.L
666 Views, 2 Replies
Is someone know the command to add the activate drawing to the project ?
My problem is that, I am generating various drawing and I would like to add them to a project, If someone know how to do that, It can help me.
ei:
Sub test2()
Dim AcadObj As AcadApplication
Dim AcadDoc As AcadDocument
On Error Resume Next
Set AcadObj = GetObject(, "AutoCAD.Application")
If Err.Number <> 0 Then
    Set AcadObj = CreateObject("AutoCAD.Application")
    NombreDessinAutocad = 2
End If
AcadObj.Visible = True
Set AcadDoc = AcadObj.Application.Documents.Add("C:\PATH\Cartouche_V1.0.dwt")
Set AcadUtil = AcadDoc.Utility
Set AcadEspaceObj = AcadDoc.ModelSpace
Set blockRefObj = AcadEspaceObj.InsertBlock(P, "C:\PATH\Mop_V1.1.dwg", 1#, 1#, 1#, 0)
document to the project
Set ...... **Looking for the command to add my drawing to the project**
End Sub
Regards
Nico
2 REPLIES 2
metal_pro2
in reply to: Nicolas.L
I could not find any type of command to add a drawing to the project like you are looking for however you could just write some code to add the information to the project.wdp file. Its just a text file so its shouldn't be to difficult. You could also add some other info like Descriptions and Section or Subsection. Its in this format
=section
==subsection
===description 1
===description 2
===description 3
test.dwg
I use notepad to edit the ".wdp" file when I need to add lots of drawings with section and description information quickly.
You need to close the project before doing this and I always make backups of the file before changing things just in case!
rhesusminus
Hi Nico.
You should search for the VLAX-class that makes it easy for VBA to communicate with LISP, as the AcadE API is solely based on AutoLISP.
Then you should have a look in the help file.
Look for c:ace_add_dwg_to_project
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
