Hi ,
I am using AUTOCADD 2010.. I need to insert a PLC in the autocadd for starting my project.
I am tollay new to this so any materials for study would be helpful.
Nelliyan.G
Solved by cbenner. Go to Solution.
Go to Help\Learning Tools\Learning Resources for some quick tutorials. I would recommend getting some outside training for this program as there is a lot to it. Just digging in without at least the basics is only going to get you lost and frustrated. If you have a VAR they should be able to help you get some training.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
