Hello
I am creating P&ID diagrams in AutoCAD Electrical. I want to use the P&ID diagram to specifics major electrical, instrumentation, and mechanical components used in a project. The P&ID would be the first document generated in a project, a graphical proposal containing tags, descriptions equipment manufacture, and part number. This would be the first sumital to the customer before the detailed mechanical and electrical design begins. Once the P&ID is approved the component information contained within the P&ID will be used to create the detailed mechanical and electrical design. The mechanical and some electrical component will be export to the 3D world (Solidworks) probably manual process with a BOM. Here is were I am have problems, I want to be able to create my schematics by selecting component tags defined in the P&ID's but I am unable to select tags defined within the P&ID will inserting schematic symbols. I can select component in the P&ID defined within the schematic. I need the ability to link the information both direction, at times the a change will be made during the electrical design this will need to be updated within the P&ID.
Aaron
