Hello all,
Just wondering if it is possible to use the AELADDER command within autolisp to automate the creation of ladders? Just that my company's drawings are all very similar and it would be nice if there was a quick way to create the ladders, in the right spot with the right settings.
When you invoke the AELADDER command it only brings up the dialog box; is there any way to pass settings to the AELADDER command?
Solved by rhesusminus. Go to Solution.
If you know lisp, you really should have a look at the API help file:
Search for c:wd_in_ladder and enjoy!
