AutoCAD Electrical General Discussion
johnq
Message 1 of 11 (660 Views)
Using ACE2012 to draw Isometrical circles
660 Views, 10 Replies
12-02-2012 03:20 PM
HI folks
Do any of you folks ever uses ACE2012 to do strtaight mechanical drawings?
I swap the profile to AUTOCAD and do my drawings.  Usually they are just variations on boxes and circles.  IE  a cabinest for a shettie to make.   Nothing fancy using splines.
I have noticed that some functions that are in 2005/7 seem to be missing but i can get around these so I will not bore yo with these details.
What I cant do is an Isometrical circles.  I could do these using 2005 so it is not I cant do 'em,  I do not seem to be able to do them using the CAD function in ACE2012.
Has any one actually drawin Iso Circles using ACE2012
Cheers  John Quigley
rhesusminus
Message 2 of 11 (628 Views)
Re: Using ACE2012 to draw Isometrical circles
12-06-2012 01:07 PM in reply to: johnq
Hi.
Use the DSETTINGS command to enter the drafting setting dialog.
Set snap to iso, and make sure you have the old-fashion dotted grid in model space.
Now, use the F5 function key to toggel between the iso-planes. Draw circles with the ELLIPSE command, using the option Isocircle (which is only available when snap is set to isometric).
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
johnq
Message 3 of 11 (620 Views)
12-06-2012 07:41 PM in reply to: rhesusminus
Hi
Thanks you for taking the time to answer my question.   I am afraid to say I have been doing what you suggested.
With some reluctance I would like to ask my question again:   Has anyone actually used ACE2012 in ACAD mode to draw Isometric circles?
Kibnd regards  John QUigley
rhesusminus
Message 4 of 11 (614 Views)
12-06-2012 10:02 PM in reply to: johnq
To answer your question: Yes.
What appears to be the problem?
Trond Hasse Lie
johnq
Message 5 of 11 (584 Views)
12-09-2012 03:18 PM in reply to: rhesusminus
Hi
My problem is I cant draw isometric circles using the ACAD profile in ACE2012.
I am quite familiar with this function using AC2005/07 Mechanical 9 but I cant make it work in ACE2012.
Cheers  john q
rhesusminus
Message 6 of 11 (579 Views)
12-09-2012 05:35 PM in reply to: johnq
Can you be a little more specific?
Is the problem setting the snap/grid to isometric?
Doesn't the F5-key work to change iso-plane?
Having trouble with the ellipse-command?
Trond Hasse Lie
johnq
Message 7 of 11 (573 Views)
12-09-2012 06:36 PM in reply to: johnq
G'day
It is the elllipse command that is not working.  I am unable to get to the INSCRIBED parameter.  F5 is changing the crosshairs.
Icemanau
Message 8 of 11 (566 Views)
12-09-2012 09:39 PM in reply to: johnq
F5 changes the crosshairs according to the ISOMETRIC views.
Did you follow the step by step instructions from an earlier post?
If so, you should have a grid showing in isometric format. The F5 toggles which view you want to work in. This is reflected in the crosshairs changing.
The other problem is, you are trying to use the incorrect command. You need the ELLIPSE command, then the ISOCIRCLE option rather than the INSCRIBED option.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
rhesusminus
Message 9 of 11 (528 Views)
12-12-2012 01:52 AM in reply to: johnq
First of all, the ellipse-command does not have an "Inscribed" option. The polygon-command does.
Second, the "Isocircle" option for the Ellipse-command do NOT appear, unless you have set the snap to Isometric, according to the instructions above.
Trond Hasse Lie
johnq
Message 10 of 11 (479 Views)
12-19-2012 07:11 PM in reply to: rhesusminus
Hi All
My face is red,  I used the wrong word.  I do know th difference between isocircle and in/circum scribe.
I had time at home to revise how I do isometric circles on AC2007 and Mechanical2009.
The default seem to be the 3 point ellips on the older versions and the isocircle option is desplayed.
I noticed that the isocircle option would be displayed but the command line would go straight to the    enter points.
The problem could have been me not clicking on the correct symbol for an ellips.
Thanks for taking the time to assist.
Cheers  John Q
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
