What is the format for getting user columns to show up in wire numbering? The only hting I could find in a search was that I should add _%1 to my "by layer" wire number setup. This did nothing, but that answer came from a pretty old post. Any thoughts on how I do this?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
Chris,
What user columns are you referring to?
If you mean the one's from the database, I do not think you can access them that way.
In the Create/Edit Wire Type window. I figured out how to change the column headings... but there has to be a way to pull out this information somewhere.
Chris Benner
I cannot help you with this one, Chris.
I never used this feature.
Looks like they can be used in creating the layer name only. Thanks Bob! Slow but sure I'm learning what this thing can and cannot do.
Chris Benner
