The Rename User Columns under the project properties wire numbers tab allows
you to re-label the 20 columns in the Create/Edit Wire Type dialog, under
the wire spool fly-out menu. It doesn't change the function, it simply
changes the prompts from User 1 to User 20. Furthermore, if you add
something like _%1 to the Layer Name Format, anything you type into column
User1, or whatever you renamed it to, will be added to the wire layer name.
Note: You can still type information into the user columns without adding
them to the layer name format, just in case you simply want to add more
description information about the wire but not have it appear in the layer
name.
wrote in message news:5721685@discussion.autodesk.com...
We are still using 2007. In the Project Properties dialog box under Wire
Numbers is a button to Rename User Columns. I am trying to figure out just
exactly what this will do an dhow best to put it to use. So far I am coming
up dry in the "help" files. Can anyone get me pointed in the right
direction?
Thanks.
Scott
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
