In AutoCAD Electrical 2015, could not understand the exact use of the Filter by WDBLNAM value check box in the Catalog Browser dialog box when used in the lookup mode. Attached are 2 images in which i have selected it in one image and deselected it in another image. Catalog records are same in both the cases. I mean, there is no difference in the no of records by selecting it or by deselcting it. Can anybody help me?
Solved by vladop. Go to Solution.
You can define WDBLKNAM value in WDBLKNAM filed in the catalog database. Only records that have a blank WDBLKNAM value or a value that matches the block name of the symbol (or WDBLKNAM attribute on the symbol block, if attribute is defined) are displayed.
See attached image.
Excerpt from The Help:
WDBLKNAM assignment
The WDBLKNAM value filters the symbol names that display in the Parts catalog dialog box. The Filter by WDBLKNAM value option on the Parts Catalog dialog box suppresses what data displays when a catalog lookup is run for a particular component. If you perform a catalog lookup on a symbol with block name “HTD1_xxx” and the Filter by WDBLKNAM value option is selected, the only records that display are listed in the TD table of the catalog database file that have a blank WDBLKNAM value or a value in the WDBLKNAM field that matches the block name of the symbol. For example, a catalog lookup on an on-delay coil (HTD1N.dwg or VTD1N.dwg) displays all blank WDBLKNAM entries and all entries that include “TD1N” somewhere in the WDBLKNAM field. If this option is not selected, the query ignores the check on the WDBLKNAM field and returns all catalog information.
You can do one of the following to determine how your catalog content is filtered:
Tip
Option 2 or 3 is preferred.
Vladimir
