I'm a new user to AutoCAD Electrical 2009 and I'm wondering where the default library path is for the IEC Symbols. I know I installed all libraries during the setup, but only the following libraries:
Hyd_Iso125
jic1
jic125
panel
Pid
pneu_iso125
<mongerson> wrote in message
href="news:6087736@discussion.autodesk.com">news:6087736@discussion.autodesk.com...
Hyd_Iso125
jic1
jic125
panel
Pid
pneu_iso125
appear in the "C:\Documents and
Settings\All Users\Documents\Autodesk\Acade 2009\Libs" directory. If I could
find the library path, I may be able to use the project manager properties to
assign the desired library to the project. I would much appreciate anyones
help as to how I can start using these IEC symbols.
<swileavat> wrote in messageGo
href="news:6088490@discussion.autodesk.com">news:6088490@discussion.autodesk.com...
to your Control Panel and in the Uninstall Programs dialog you can press
Uninstall/Change on Electrical. That will let you run through the setup and
change what options were installed originally. Stan
"mongerson" wrote in messageWell
href="news:6096333@discussion.autodesk.com">news:6096333@discussion.autodesk.com...
it is the 30-Day Trial Version, but it gave me the option to install the
libraries? I don't think its because it's the trial, but maybe it could be? My
local authorized AutoCAD reseller wasn't sure..
