AutoCAD Electrical Forum
Updating WD_M
2 REPLIES 2
dbrblg
626 Views, 2 Replies
Updating WD_M
When I try and update the WD_M block using the 'Update to new WD_M Block, Values and Layers' command, I get the following error in the command window:
Command:
PANEL:
Type "swap_pnlm" to swap and conv to new lays carried on new wd_pnlm.dwg
Type "swap_pnlm_keep" to swap but keep drawing's existing layer names
SCHEMATICS:
Type "swap_wdm" to swap and conv to new lays carried on new wdm.dwg
Type "swap_wdm_keep" to swap but keep drawing's existing layer namesBlock WD_M references itself
*Invalid*
I'm not sure how this block can reference itself??!!??!!  I am using ACADE 2014 and as far as I can remember it worked in previous versions.  Could it be a setup issue?
2 REPLIES 2
rhesusminus
in reply to: dbrblg
I would take a look at the WD_M.DWG-block in your symbol library.
Seems like it contains a block named WD_M.
Make sure all objects in this file is "exploded", and use the PURGE command to remove all blocks.
Try again.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
dbrblg
in reply to: rhesusminus
Thanks rhesusminus, looks like I forgot to purge wd_m Smiley Mad
