Good day,
There is an API call in the AutoLISP Reference guide that might help. This is to process one drawing at a time but you could script it to make it work for what you are trying to do.
(c:wd_tb_process_one suppress togglelst) - which is located under Section E - Drawing Setup of the AutoCAD Electrical AutoLISP Reference supplied with autoCAD Electrical.
The togglelst includes a list of several items and the refers to what you have the title block setup mapped to. You basically turn the bits on or off. Here is the entire snipit from the help file.
AutoLISP
Parameters
Parameters Description
suppress 1 to suppress any error alert boxes, 0 to allow.
togglelst list of update toggle flags consisting of a 13-element sublist and then followed by a variable length list of LINEn index numbers. First sublist (of 16 elements, 1 for selected, 0 for not selected), described below. After this sublist, give the integer values of the "LINEn" index numbers to process where index value= n-1, that is, "zero-based" (ex: LINE1 index value=0, LINE20 index = 19). This list of LINEn attribute references can be zero to unlimited length. 1st = mapped to DWGDESC (the description under drawing "properties").
2nd = mapped to DWGSEC.
3rd = mapped to DWGSUB.
4th = mapped to FILENAME.
5th = mapped to FILENAMEEXT.
6th = mapped to FULLFILENAME.
7th = mapped to DWGNAM.
8th = mapped to SHEET.
9th = mapped to SHEETMAX.
10th = (not used for single drawing update)
11th = mapped to IEC_P (the drawing's IEC coding default for %P).
12th = mapped to IEC_I (the drawing's IEC coding default for %I).
13th = mapped to IEC_L (the drawing's IEC coding default for %L).
14th = mapped to 1st line only of DWGDESC
15th = mapped to 2nd line only of DWGDESC
16th = mapped to 3rd line only of DWGDESC
Description
Update title block attribute values.
Example 1
Update TB of active dwg, update attribs mapped to LINE1, LINE2, LINE3, and LINE37 as displayed in the UPDATE TB dialog box.
(c:wd_tb_process_one 0 (list (list 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0) 0 1 2 36))
Example 2
Update TB of active dwg, update attribs mapped to three lines of DWGDESC, SHEET, LINE2-3 and LINE12.
(c:wd_tb_process_one 0 (list (list 1 0 0 0 0 0 0 1 0 0 0 0 0 1 1 1) 1 2 11))
Example 3
Update TB of active dwg, update SHEET and SHEETMAX only.
(c:wd_tb_process_one 0 (list (list 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0)))
I hope this helps
Real Software Solutions
