Hello all,
Quite simply, I have to update an existing project with Japanese descriptions.
It's not a problem for components or any descriptions on my schematic.
My issue lies in the Title Block.
1.If I go to my Project Descriptions and update my details (Let's say the description is "GENERIC DRAWING 回路") and update my title block, any Kanji (Japanese Text) shows up as "????".
2. So, I figure I need to update my title block to accomodate this style of text. I create a new Title block with the correct font style.
3. Now I do a project wide swapblock. The old title block with the wrong text style to the new one with the proper text style (I changed the title block name as well).
4. I now do a project wide title block update, but no dice. Any Japanese text comes up as ????.
Is my problem in the way I'm updating my title block or do the font styles automatically default to ROMANS?
Thanks!
Lou Branchaud
Electrical Designer
If the input language is not supported, you may be getting the results you see due to Windows over-riding the ACAD settings.
Make sure that Windows has the correct language installed. The methods may vary depending on what version of Windows you are running.
This is taken from the Windows 7 help...
To add an input language
Click the Keyboards and Languages tab, and then click Change keyboards.
Under Installed services, click Add.
Double-click the language you want to add, double-click Keyboard, select the text services options you want to add, and then click OK.
Before you can change the input language that you want to use, you need to make sure that the input language has been added.
Click the Input language button on the Language bar, and then click the input language you want to use.
If you don't see the Language bar, right-click the taskbar, point to Toolbars, and then click Language bar. For more information about the language bar, see The Language bar (overview).
In addition to changing the input language, you can also customize your keyboard for a specific language or format. For more information about customizing your keyboard, see Change your keyboard layout.
Other versions of Windows may vary.
Regards Brad
Brad Coleman, Electrical Draftsman
Hello Brad,
I don't think that's the issue.
I'm mostly trying to change the font used in the title block (I'm using a font that can handle two types of characters / languages).
I'd like to know if I can do this project wide rather than on individual pages.
I you double click the title block, and change the text style on the attrbiutes manually on one drawing sheet like this:
When you run the title block update now, do the japanese characters appear?
