No I don't mean attributes. I'm talking about the standard Autocad field,
which is inserted via the 'Insert/Field' command from the drop down menus. I
use the field to duplicate data from certain attributes in the title block
elsewhere in the title block (ie duplicate drawing number). Our title blocks
have 2 copies of the drawing number to allow for different ways of folding
the drawing. By using fields we only have to change One number when we setup
the drawing.
The problem is, If you make a change and update the block using the
Electrical block update command, the field loses it's connection to the
attribute it was getting it's data from.
Regards Brad
"Doug McAlexander" wrote in message
news:5805562@discussion.autodesk.com...
Not sure what you mean by fields, but let me take a shot. If you are
referring to a symbol that has been inserted into a schematic page and
attribute values have been assigned, then you change the block, you can use
update block to purge the older version off the drawing(s) and replace them
with the new version. However if the change you make to the block involves
the attributes, and you have the radio button marked to discard old
attribute values, you will lose data that was inserted from the insert/edit
dialog. The default is to copy the old values to the new block, but if you
select to discard old values you will get blanks.
This may not be your problem, but I'm just not quire sure what fields you
are referring to. The schematic symbols have attributes in them. When
you enter text into the description boxes, MFG, CAT, etc. this data is
stored as attribute values and recorded in the project scratch database. If
you update a block the default is to delete the existing block, purge,
replace with the new version of the block, and copy the text data from the
scratch database back into the attributes.
