AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Update Title Block - Edit Menu Options
4 REPLIES 4
403 Views, 4 Replies
I would like to edit the per-drawing section of the Update Title Block menu. Where can I find the dcl, or other, file that controls the visual aspects of this menu? I like that Autodesk gave this title block update option but the values that are used by default will not work for my company and I have been asked to find a way to make this menu better fit our needs for it.
On a side note,
Why was the project wide portion of this menu created to give the user many easily edited options and the per-drawing section not given this same option? Autodesk could have kept the default options that are provided currently in this menu but also offered a small section similar to the customizable project wide lines in the per-drawing section. This is what I am after with finding this file, I would like to do just that. If I have to adjust the default values I will but I would like to get the files that this menu interact with to see if I can add the formentioned customisable lines to what Autodesk already provides.
Thank you for your help.
4 REPLIES 4
This is what I am after... Customising this menu...
Tee.Dee
see this link:
http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0777-Project-777/0789-Title_Bl789/0796...
The .wdl file is just a notepad file where you change the extension from .txt to .wdl
The format of the file looks something like this:
LINE1=CLIENT
LINE2=DRG NO.
LINE3=REF NO.
LINE4=REV NO.
etc.
in reply to: Tee.Dee
I am well aware of how to customise the "Project Wide" section of this menu... I would like to customise the "Per-drawing" section of this menu.
testsubject
I think I see what you are getting at.
I would agree with you that it would be nice to have the ability to set up more than just 3 description lines per drawing. I also would like to have a per drawing Rev Change availability. That would require adding 12-16 extra user data fields to the drawing side. Not sure how difficult that would be I second the recommendation to add it.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
”Boost
