I have a terminal strip in the schematic. I also created the terminal strip in the terminal strip editor.
How do I change the name of this terminal strip once these are created? If I change the tag strip (using edit component) in the schematic it does not update the footprint and vice versa.
The update the terminals (one by one) to the new tagstrip name. Delete the tagstrip from the panel drawing. and recreate the new one with TSE. There must be a better way.
Have you tried the Reassign button in TSE? You can use this to "rename" terminals...
THL
