AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Update of Line Reference Styles
1 REPLY 1
amh90hewitt
296 Views, 1 Reply
Good Afternoon everyone,
We currently use the hexagon with sheet and line number as our symbol for line references. Recently, we adopted using 0.5" spacing (rather than 0.75") so we opted to change the line reference style. I know the style is established at the project level under drawing format in properties. I have started a project using the hexagon style line reference but now want to change. Is there some sort of automatic update to convert them or will it need to be manually done?
Thank you,
Aaron
1 REPLY 1
in reply to: amh90hewitt
If you want to change ladder or cross reference style in drawing then go for following path
Schematic Tab->Edit wires/Wire numbers pallette->Revise Ladder.
Then specify input for ladder spacing,or reference no.s
OR if you want to change Block used for references automatically in dwg or project at a time then:
Select Schematic Tab->Edit Components Pallete->Swap/Update Block/Library Swap.
”Boost
