Maybe I'm missing some of this thread, but just in case, AcadE does need to
see certain attributes in schematic and footprint blocks in order to track
and report the data (i.e. BOM, wire list, etc.). You can use the symbol
builder to add the appropriate attributes to any block or even dumb geometry
to create an intelligent block (symbol). There is a specific block naming
convention that must be adhered to in order for AcadE to manage wire
connections, part number searches, and parent-child relationships. The
Symbol Builder will suggest an appropriate name. Anything past the
underscore can be replaced with your own choice of text, or removed
altogether. You can removed the underscore if you do not need to add any
additional symbol description text.
Note: If you create your own PLC block, outside of the PLC Database File
Editor, the file name must begin with the letters PLCIO in order for AcadE
to bring up the special component edit dialog screen for PLC data, when you
click Edit Component and select a PLC module. This special version of the
Edit Component dialog has entries for PLC addresses and description lines.
"Steve"
wrote in message
news:5904933@discussion.autodesk.com...
Currently, the main source for PLC's in AutoCAD Electical will be what comes
with it. To my knowledge there is no additional AutoCAD Electical data on
the Unity Pro disks. Now this is not to say you can not find additional
data out there on the web somewhere that will work with Acade and maybe
there are other user willing to share data that they have added.
As for footprints, Acade is pretty open to using any blocks, they don't need
to have any specific Acade atributes on them, so you can take about any
AutoCAD DWG footprint block supplied by a manufacturer and use it in Acade.
There are a lot of manufacturers that do supply this info.
Steve
wrote in message news:5899593@discussion.autodesk.com...
Ahh. I see. I assume that there are other modicon PLC and remote IO
components available through other sources if I can't find them in the mfg.
data that comes with AutoCAD. I've not checked, but I wonder if the
database files for more modules and possibly the footprint info as well
might reside in the Unity-Pro installation disks...
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
