AutoCAD Electrical General Discussion
Valued Contributor
crosby.109
Message 1 of 4 (194 Views)
Unique Attributes on Symbol not Linking to Footprint
194 Views, 3 Replies
02-13-2014 11:58 AM
When creating a unique attribute in the Symbol (ex: COLOR), and adding the corresponding attribute to the Footprint (ex: color), When laying down the Footprint from schematic component it doesn't find that value.  It WILL work if I do the same thing but change the attribute name to somthing familiar like RATING1.
I just dont want to use these attributes.  Any thoughts why it isn't linking?
Thanks!
I guess you're stuck with using the RATING attributes.
However, if you put a description for the rating in the prompt-field, it will display in AcadE's dialog:
Valued Contributor
crosby.109
Message 2 of 4 (187 Views)
Re: Unique Attributes on Symbol not Linking to Footprint
02-13-2014 12:15 PM in reply to: crosby.109
i just tried adding a number to end (ex: COLOR1) but still no luck.  Let me know if anybody can get this to work . . . it seems like a relatively fundamental issue
rhesusminus
Message 3 of 4 (175 Views)
02-13-2014 03:23 PM in reply to: crosby.109
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Valued Mentor
drathak
Message 4 of 4 (163 Views)
02-14-2014 11:38 AM in reply to: crosby.109
The problem is that the underlying code doesn't have any way to know about those additional attributes or be able to match them up.  The "known" attributes are hard coded into the software.
Would be very nice if it did work that way though.  But for now, you have 12 RATING attributes to play with.
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
