AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
uniform "insert component menu" for all computer
2 REPLIES 2
206 Views, 2 Replies
I already update/change “insert component menu” in my computer,
I have to make same icon (interface of “insert component menu”) in another computers, how to make all computer in my office have a same interface with my?
For your information I’m using ACE2008 network version.
2 REPLIES 2
cawaugh
If you used the icon wizard to make your changes or edited the wd_menu.dat file directly, just replace the other computers wd_menu.dat with the one you edited. It can be found at C:\Documents and Settings\"USERNAME"\Application Data\Autodesk\AutoCAD Electrical 2008\R17.1\enu\Support.
The other way you can do this is to put a "Support" file with icon slide library folder and wd_menu.dat on the server and add a path in "Options" Support File Search Path to the Server Support folder and to the icon slide library.
This way you don't have to update each individual computer whenever you add to the icon menu
”Boost
