AutoCAD Electrical Forum
Unhandled Error
3 REPLIES 3
twright
151 Views, 3 Replies
Unhandled Error
Ater updating ACE2006E with Service pack 1, I constantly get an error message when selecting editing commands. Insert Component, Insert PLC...practically every command yet the program continues on without shutdown. (See attached doc for error message)
Running XP 64-bit Professional
Acad2006 Electrical
This did not occur prior to the service pack install.
(How to uninstall?)
3 REPLIES 3
twright
in reply to: twright
Proper error message
Maybe you can try installing the .NET framework from microsoft and see if it
works, not sure whether this will solve your problem or not. XP 64-Bit
professional is not supported by AutoCAD Electrical. SP1 alone cannot be
removed, you will need to uninstall the package and reinstall the release
version only.
Sorry, for not being much of a help.
Giri.
wrote in message news:4963293@discussion.autodesk.com...
twright
Thanks for the input. Will probably go that route when it gets to annoying or starts crashing the program but for now one must make a living......
”Boost
