AutoCAD Electrical General Discussion
New Member
0 Kudos
Post 1 of 2
UNDO command went crazy
214 Views, 1 Replies
12-04-2012 04:01 AM
I’ve been using AutoCAD Electrical for some months without problems.
Last week my UNDO command went crazy
Each time I open a file, it is turned off or disabled.
I type undo in the command line and I receive the actual settings
“Current settings: Auto = Off, Control = None, Combine = Yes, Layer = Yes
Enter an undo control option [All/none/One/Combine/Layer] <All>:”
I press enter key, and type undo again, the settings were changed
Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Now every thing it’s OK.
I have tried FILEDIA and UNDOCTL, without success.
Probably it’s very easy, but I do not know how to fix it.
Regards
PB
Valued Contributor
2 Kudos
Post 2 of 2
Re: UNDO command went crazy
12-10-2012 11:30 AM in reply to: pmbernardo
I kow how you feel. I'm going through the same thing, see my post
http://forums.autodesk.com/t5/AutoCAD-Electrical/Undo-command-disabled/td-p/3724200
And appearently this has been an acade bug for a long time.
Jim
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
