AutoCAD Electrical Forum
UNDER THE PLC PARAMETRIC SELECTION I can't find find the 1769-ASCII in the list?
2 REPLIES 2
cadmando1960
478 Views, 2 Replies
On AutoCAD Elelctrical I can't find ASCII module on the PLC parametric selection? Do you substitute with another module?
2 REPLIES 2
The 1769-ASCII module isn't in the list yet.  I checked to see if it is in the latest content update of AB data as well.  It is not.  You can use the PLC Database File Editor to add additional modules as needed.  I would suggest adding the ASCII module to the Special category.
For future reference, you can download content as they become available.  Below is the link for release 2014 AB content updates.
http://knowledge.autodesk.com/support/autocad-electrical/downloads/caas/downloads/content/autodesk-C...
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
ccad2509
in reply to: dougmcalexander
Check this to find out why autodesk dosent have up to date databases
http://forums.autodesk.com/t5/autocad-electrical-general/allen-bradley-vfds/m-p/5383181#M38047
:smileyfrustrated:  PS why did it take you 10 years to put in the next page / previous page attributes in the page border when your competitors have done it from the start ?
:smileyfrustrated:  PPS why did it take autodesk so long to fix this problem when it was obviously there from the start?
http://forums.autodesk.com/t5/autocad-electrical-general/title-block-issue-in-iec-demo-project/td-p/...
”Boost
