AutoCAD Electrical Forum
unable to communicate with project database service error
10 REPLIES 10
Message 1 of 11
3463 Views, 10 Replies
Every time I open AutoCAD Electrical 2012 i come up with the following error "unable to communicate with project database service error" What can i do to fix this problem? if I open up the Error tab it says ythe following:
"Row #:    0 Source: "Microsoft OLE DB Service Components"
Description: "Class not registered"
Help File: "(null)" Help Context:    0
GUID: {2206CCB1-19C1-11D1-89E0-00C04FD7A829}
Unable to create Access database file 'C:\Documents and Settings\randall\Application Data\Autodesk\AutoCAD Electrical 2012\R18.2\enu\Support\user\POINT2POINT.mdb'
Any project i try to open gives me the "unable to communicate with project database service error"
Also if i try to insert an PLC i get the following error "Unable to load PLC Database:
C:\Documents and Settings\randall\My Documents\AcadE 2012\AeData\plc\ACE_PLC.MDB
does any one have any answers for these problems?
10 REPLIES 10
Message 2 of 11
leeholl
It sounds like something you have added or removed from your system has unregistered the Microsoft Ole DB components. You can try registering your OleDB dll again using the following:
regsvr32 %windows%/system32/ole32.dll
If that doesn't help, you will need to do a Google search ("Microsoft OLE DB Service Components" "Class not registered") for the appropriate solution as this is a Windows issue, not ACADE.
Lee
Message 3 of 11
in reply to: leeholl
I had the same problem after running a registry maintenance program.  I was able to fix the problem by doing an installation repair from the Windows add/remove programs.
Message 4 of 11
I have exactlly the same problem! I have been fighting it for two days now!! Someone please help us!!
Message 5 of 11
This use to be caused by the MSJET DLL file not being correctly registered.  You can try the following.  This is for Windows 7, if you are using a different Windows version the DLL files might be in a  different location:
  1. Exit AutoCAD Electrical
  2. From the Start menu, in the 'Search programs and files' edit box enter:
                    regsvr32 c:\windows\sysWOW64\MSJET40.DLL
                    You should receive a Succeeded message
  3. From the Start menu, in the 'Search programs and files' edit box enter:
                    regsvr32 c:\windows\sysWOW64\MSJETOLEDB40.DLL
Steve
Message 6 of 11
I did exactly as you requested.
The problem is still there! This is so frustrating!
Thank You for your help!!
Anymore ideas?
Paul Reed
Controls Specialist
preed@amtec-corp.com
Office (256) 319-6287
Cell: (256) 653-5100
Fax: (256) 319-6270
Web:www.amtec-corp.com
Solutions. Concept to Reality
DESIGN - BUILD - TEST
This e-mail and any attachments may contain information that is
confidential, privileged, proprietary or otherwise protected by law. The
information is solely intended for the named addressee (or a person
responsible for delivering it to the addressee). If you are not the intended
recipient of this message, you are not authorized to read, print, retain,
copy or disseminate this message or any part of it. If you have received
this e-mail in error, please notify the sender immediately by return e-mail
and delete it from your computer.
Message 7 of 11
leeholl
Can you post the exact error message you are seeing? The steps provided by Steve should have solved the problem.
Lee
Message 8 of 11
Hi!
I had the same error and I work with Windows 7 and AutoCAD Electrical 2014.
I tried to register the libraries ole32.dll, msjet40.dll and msjetoledb40.dll with the administrator privilege, but that did not resolve my error.
So, I tried to repair my AutoCAD Electrical 2014 (Control Panel > Programs and Features > AutoDesk AutoCAD Electrical 2014 > Uninstall/Change and then Repair) but that did not resolve my problem.
Finally, my solution was to rename my user profile folder “AutoCAD Electrical 2014” of “%appdata%/Autodesk” (equals to“C:\Users\<My User>\AppData\Roaming\Autodesk” in Windows 7 or “C:\Documents and Settings\<Mu User>\Application Data\Autodesk\AutoCAD Electrical 2014” in Windows XP).
Renaming this folder (for example by “AutoCAD Electrical 2014_OLD”), my user profile folder is recreated when I run AutoCAD Electrical 2014 for the first time.
I hope that can help anybody who goes to this forum to encounter a solution.
PS: Sorry for my pour English.
Bye
Message 9 of 11
mccla5214
Don't worry about your English when you can come up with a fix that works!!!!!!!!!
Message 10 of 11
mayrcQGDBS
Per the attachment I cannot get ACADE 2015 to open. The results of Steve's test is included. The inital test being successful. Where can I find and insert the dll?
Message 11 of 11
mayrcQGDBS
in reply to: mayrcQGDBS
I tried it again and it worked correctly. I tested ACADE again and had the same issues. Will reboot and try again.
”Boost
