Show only
Search instead for
msg65stang (for lack of the appropriate name),
Are you trying to add them by using the strip editor? what version of ACE
are you running?
Mauro
wrote in message news:5704115@discussion.autodesk.com...
I am unable to add terminal strip to panel dwg. I can insert them into a
schematic then copy. All other panel components inserted ok.
Yes it does not insert the preview of the terminal strip when I am using Autocad E 2006 and also does not insert the terminal strip when I am using Autocad E 2008. could it be a setting in the WD_PNLM block?? I have other panel drawings in other projects that I can insert the terminal strip with no issues.
TSE fails to insert the panel strip when the WD_M or the WD_PNLM block (or
both) are not found in any of the search paths the active project is set
for. That explains why with some projects it works just fine and with some
other it does not.
Mauro
wrote in message news:5704742@discussion.autodesk.com...
no issues.
