AutoCAD Electrical General Discussion
Active Contributor
pseguy2007
Message 1 of 6 (3,992 Views)
txt2mtxt command
3992 Views, 5 Replies
07-26-2012 12:41 PM
Just got upgraded to Electrical 2013. my favorite text command is no longer useful. That is the "txt2mtxt" command....I need this back!...Any other commands like this?
Distinguished Contributor
Tee.Dee
Message 2 of 6 (3,988 Views)
Re: txt2mtxt command
07-26-2012 03:44 PM in reply to: pseguy2007
It may or may not be obvious but do you have the express tools loaded?
Employee
RobinShou-Autodesk
Message 3 of 6 (3,982 Views)
07-26-2012 10:21 PM in reply to: pseguy2007
This is a known issue for ACE2013, we are working on the fix for it now.
Please refer to the workaround in the following link for now:
http://www.youtube.com/watch?v=952RR_h0HhI&feature=player_embedded
Robin Shou
Quality Assurance
AutoCAD Electrical
SGY
Active Member
SGY
Message 4 of 6 (3,955 Views)
08-01-2012 02:10 PM in reply to: RobinShou-Autodesk
I am having the same problem of some express tools not working in Structural Detailing, 2013. Your tip of manually loading LEADEREX.ARX also works for Autocad Structural, 2013.  Great tip, thank you.  I hope Autodesk fixes this problem.
New Member
Mastermind4000
Message 5 of 6 (3,603 Views)
12-28-2012 01:02 PM in reply to: pseguy2007
Hi pseguy2007,
I am working in AutoCAD MEP 2013 and the command didn't work in there but it worked in regular AutoCAD 2013. After more research I found that the command is in leaderex.arx and is not a Lisp Routine. Load it (leaderex.arx) into your AutoCAD Electrical 2013 using the appload command while you are in a drawing. Make sure you add it to your History folder and add it to the contents of your Startup Suite as well. Save and close the drawing and AutoCAD. Now it should be working when you reopen AutoCAD.
The Express folder should be located here: C:\program files\autodesk\autocad 2013\express
Let me know if that helps.
New Member
Mastermind4000
Message 6 of 6 (3,601 Views)
12-28-2012 01:03 PM in reply to: RobinShou-Autodesk
Is the fix in Service Pack 1?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
