I am currently running AutoCAD Electrical 2016. I have 'lost' the use of the Properties Palette. Or, maybe it is hidden off screen (I am running two screens)? At any rate, I want it docked on the right of my drawing area. I have experienced this problem intermittantly. Not sure why. Has anyone else experienced this and, if so, how did you fix it?
I don't have 2016, but typing "PROPERTIES" in the command line should bring it back. If that doesn't work, that may indicate that it is off-screen somewhere that you can't see. If that's the case, I'm not sure how you can find it.
However, if you can get the Properties palette back, then go ahead and position it the way you want, and save the workspace. That should help it to stay put.
Hope this helps,
Jim
Thanks Jim,
I'm very experienced with AutoCAD and not unaware with AutoCAD Electrical.
I have already tried all the things you mentioned. I seem to remember there was a way to get off-screen palettes and tools to reappear, but cannot remember what that was and I'm not even sure it would help in my case.
Any other ideas?
This was the fix...
Type CUI at command line > Return > select the work space you work in (upper left window) > select Palettes (upper right window) > scroll down and select Properties > make the following changes (see attached picture) and close/restart AutoCAD.
For some reason "Show" was set to "No", and the "Size" were both zero (0). Not sure if the settings will 'stick', but it's working right now.
There is a way to "drag" a dialog box that is off screen back to on screen.
Press ALT+Spacebar then press M. Now you can use the arrow keys to move the dialog box around.
THANK YOOOOOOOOOOO! Seems so easy, why can't they just say "Type TOOLPALETTES" in the Help section to turn it on? JEEZ!!!
