style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<svend007> wrote in messageI'm
href="news:6090001@discussion.autodesk.com">news:6090001@discussion.autodesk.com...
working on a project where 2 identical circuits are contained within a single
panel/cubicle. So, I created a schematic diagram for the first cct, then
copied the drg (using save as), then changed all of the LOCation codes from,
say TCP1 to TCP2, etc for the second circuit and made some v.minor changes,
and then added the drg to the project. I then run the drawing audit report,
which just is something I do regularly. The problem arises on inserting the
terminals onto the footprint/wiring diagram. Using the TSE, I insert the
terminals for the first circuit, which is fine, but upon inserting those for
the second cct, most of the terminals for the first cct disappear. TSE seems
to be confused as to which terminals belong to which, but I've checked that
the LOC values are different for each set, so what's happening. I can't
remember if I started the footprint/wiring diagram before I copied the
original schematic. Would this affect anything, especially if I'd added the
terminals to it before copying the schematic? Could it possibly be anything to
do with Terminal associations? Are these created between Schematic and
footprint/wiring diagram and if so how can they be erased or reset? Thanks to
anyone taking the time to reply. Cheers, Pete B.
"Pat Murnen (Autodesk)" <
href="mailto:nospam_pat.murnen@autodesk.com">nospam_pat.murnen@autodesk.com>
wrote in message
href="news:6090119@discussion.autodesk.com">news:6090119@discussion.autodesk.com...
The most important thing here is that when you
add the drawing to the project through Project Manager, when it alerts you
that duplicate terminal linkterm values exist that you select to have the
linkterm values updated on the drawing(s) you are adding. This should ensure
that the linkterms are then unique on this "copied" drawing from the original.
I believe there was a .lsp file posted that can clear out the linkterm values
on a drawing. You might search for that if you want to go that route. The only
downside to clearing the linkterm values out is if you are using any
multi-level terminals. They will no longer be associated. The other idea might
be to remove the copied drawing from the project. Then add it back in using
Proejct Manager and the alert should show up. If the linkterm values are
updated this way then any multi-level terminals that are on the drawing(s)
being added stay associated.
Pat Murnen
single panel/cubicle. So, I created a schematic diagram for the first cct,
then copied the drg (using save as), then changed all of the LOCation codes
from, say TCP1 to TCP2, etc for the second circuit and made some v.minor
changes, and then added the drg to the project. I then run the drawing audit
report, which just is something I do regularly. The problem arises on
inserting the terminals onto the footprint/wiring diagram. Using the TSE, I
insert the terminals for the first circuit, which is fine, but upon
inserting those for the second cct, most of the terminals for the first cct
disappear. TSE seems to be confused as to which terminals belong to which,
but I've checked that the LOC values are different for each set, so what's
happening. I can't remember if I started the footprint/wiring diagram before
I copied the original schematic. Would this affect anything, especially if
I'd added the terminals to it before copying the schematic? Could it
possibly be anything to do with Terminal associations? Are these created
between Schematic and footprint/wiring diagram and if so how can they be
erased or reset? Thanks to anyone taking the time to reply. Cheers, Pete
B.
<svend007> wrote in messageThanks
href="news:6090483@discussion.autodesk.com">news:6090483@discussion.autodesk.com...
for your input Pat. Re: your first post, I/we don't use multi-level terminals,
so that wouldn't be a problem. I used quick properties to delete all the
linkterm values in the drg for the second cct, then re-inserted the terminals
in the wiring diagram using TSE, which seemed to work fine, but then when I
came to add the INST values for these terminals (which at this stage were
blank on both schematic and wiring diagram) I had problems keeping them in
synch. In the end I had to change the INST values on the two drgs
independently. Anyway, I guess the best thing to do, where possible, is not
add any terminals to a footprint/wiring diagram until all the schematics are
complete.
<hw@pw> wrote in messagecan
href="news:6092913@discussion.autodesk.com">news:6092913@discussion.autodesk.com...
somebody take a minute and explain to me how to use a lisp function? i tried
to find it in the "help" but couln't make any sense out of it. greatly
appreciated!
wrote in message
href="news:6090197@discussion.autodesk.com">news:6090197@discussion.autodesk.com...
It looks like there is a reported issue with
updating the linkterms when you add a drawing to a project. I will post
something if/when I get more information on this.
Sorry for this inconvenience,
Pat Murnen
wrote in message
original. I believe there was a .lsp file posted that can clear out the
linkterm values on a drawing. You might search for that if you want to go
that route. The only downside to clearing the linkterm values out is if you
are using any multi-level terminals. They will no longer be associated. The
other idea might be to remove the copied drawing from the project. Then add
it back in using Proejct Manager and the alert should show up. If the
linkterm values are updated this way then any multi-level terminals that are
on the drawing(s) being added stay associated.
Pat Murnen
codes from, say TCP1 to TCP2, etc for the second circuit and made some
v.minor changes, and then added the drg to the project. I then run the
drawing audit report, which just is something I do regularly. The problem
arises on inserting the terminals onto the footprint/wiring diagram. Using
the TSE, I insert the terminals for the first circuit, which is fine, but
upon inserting those for the second cct, most of the terminals for the
first cct disappear. TSE seems to be confused as to which terminals belong
to which, but I've checked that the LOC values are different for each set,
so what's happening. I can't remember if I started the footprint/wiring
diagram before I copied the original schematic. Would this affect
anything, especially if I'd added the terminals to it before copying the
schematic? Could it possibly be anything to do with Terminal associations?
Are these created between Schematic and footprint/wiring diagram and if so
how can they be erased or reset? Thanks to anyone taking the time to
reply. Cheers, Pete
B.
Pat, I don't think this was ever fixed. I still see the issue today. I just delete the duplicate terminals in TSE.
