AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
TSE- Entire Terminal Number Not Showing Up
1 REPLY 1
231 Views, 1 Reply
I have attached a screen shot of what my terminal strip editor is showing as far as terminal numbers.
For this perticular project, our terminals have to match the wire number completely and we ended up with long terminal numbers. I went into the scrdbmdb.wds file and changed everything that had to do with terminal numbers to 24 characters (unless it was more)and also rebuilt the project database. Still didnt change. Is there another script file that affects the tse?
By the way this is only affecting schematic terminals with wire change, in which I manually entered the terminal number. Schematic terminals that accept the wire number as the terminal number have no issues showing the full number, as you can see.
1 REPLY 1
I forgot to circle the terminals I was mentioning, this should be more clear.
”Boost
