I am looking for a command that I knew once, it would show all activity on the commandline that AutoCAD processes with its command, not just the information relevant to the average user. It is used mostly for troubleshooting what AutoCAD is doing when a command processing.
I believe I heard about it on this forum, as AutoCAD: Electrical runs a lot of extra "commands", when the user commands it.
Pardon me for the odd use of language, I hope someone out there understands what I am talking about. I would ask the Programming community here; but I am not sure if this is exclusively an AutoCAD: Electrical command.
Solved by RobinShou-Autodesk. Go to Solution.
Is this the one you are finding for? If you make the Command Trace On, then you will see lots of internal command running for ACE.
Robin Shou
Quality Assurance
AutoCAD Electrical
