AutoCAD Electrical General Discussion
*Expert Elite*
rhesusminus
Message 1 of 10 (426 Views)
Accepted Solution
Trouble with ASSYCODE
426 Views, 9 Replies
12-12-2012 01:42 AM
Hi.
I've attached a small project, showing the problem.
On one instance of a component, I wan't to add one extra of a subpart, so I change the assembly code from "AC100;AC200" to "AC100;2,AC200" manually. In the component database, the assycode is set to "AC100;AC200".
What seems to happen, is that if the assycode in the symbol doesn't match the assycode in the catalog, the description for the "main" part disappears... Not just in the catalog check, but also in the BOM report. Bug or feature?
See pictures
Before:
After:
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
If you are keying in the assembly code on the fly, for the flexibility of adding more than one subassembly part to a master part that is not set up as a master, your method should work.  But if the Master does have a code you must match the exact code.  The 2,AC200 to add a second AC200 will not represent an exact match if AC100;AC200 is the code assigned to the master.  Remove the ASSYCODE entry from the master and your code should work.  But if you want a permanent relationship of qty 1 of AC100 and qty 2 of AC200 set the Count field to "2" for the AC200 record in the catalog database.
*Expert Elite*
dougmcalexander
Message 2 of 10 (403 Views)
Re: Trouble with ASSYCODE
12-13-2012 12:53 AM in reply to: rhesusminus
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
*Expert Elite*
rhesusminus
Message 3 of 10 (400 Views)
12-13-2012 03:12 AM in reply to: dougmcalexander
So... The answer to my question is that this is a feature?
Strange though that it's just the description for the main part that disappears, while everything else is ok.
It just doesn't make any sense that this shouldn't work.
Trond Hasse Lie
*Expert Elite*
Icemanau
Message 4 of 10 (381 Views)
12-13-2012 05:49 PM in reply to: rhesusminus
According to the ACADE 2008 help files, the semi colon is the correct way to seperate different sub part codes. and the '2,' before the assembly code is the correct way to add multiple sub parts.
If this has changed in later issues it should be documented.
I have noted that if you make a change to the catalog entry, you have to select it, exit to the component edit screen and then do a second lookup and selection to have the correct data disply in the catalog check screen.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
bpasqualini
Message 5 of 10 (371 Views)
12-14-2012 02:32 AM in reply to: Icemanau
I totally agree.
I have already reported this to Autodesk last year but there was no reaction.
Best regards
*Expert Elite*
rhesusminus
Message 6 of 10 (368 Views)
12-14-2012 02:48 AM in reply to: Icemanau
This seems to be "the problem", and I have trouble seeing the logic here.
If an item in the catalog database has an assycode, the assycode in the edit component dialog MUST match the catalog.
If an item in the catalog database has an empty assycode, the assycode in the edit component dialog can be whatever you want. Empty og something you've specified manually.
I see that I works this way, but can't see any reason to why it should be like this? The flexibility of the program would be much greater if one could specify whatever one would like in the assycode textbox.
So, Autodesk: Is there a reason for the functionality to be like this, or can I add this for the wishlist of feature changes?
Trond Hasse Lie
*Expert Elite*
rhesusminus
Message 7 of 10 (267 Views)
01-03-2013 02:05 AM in reply to: rhesusminus
*bump* Autodesk?
Trond Hasse Lie
*Expert Elite*
rhesusminus
Message 8 of 10 (219 Views)
01-14-2013 10:23 PM in reply to: rhesusminus
*rebump*
Autodesk?
Trond Hasse Lie
New Member
mriley
Message 9 of 10 (69 Views)
07-30-2014 04:26 PM in reply to: rhesusminus
What i dont understand is that when these are hardcoded into the block there is no automatic update of the multiple catalog.
Am i missing something or is this another oversight??
*Expert Elite*
dougmcalexander
Message 10 of 10 (66 Views)
07-30-2014 04:55 PM in reply to: rhesusminus
If a part in the database has a check designating it as a subassembly part, there should be an Assembly List value entered. If a main/master part contains this same value (really just a text string, and spaces are allowed) in its Assembly Code field, when a BOM is generated the software will add all subassembly parts with the same assembly list value to the BOM, directly below the master part that contains the same value in its assembly code field.
If you insert a symbol and assign a main/master part number to it, the Assembly Code field will fill in with the previously designated Assembly Code value.  If you determine that, just this one time, you don't need the subassembly parts, delete the text in the Assembly Code field.
Now here is a neat trick. You have a main/master part that doesn't always need subassembly parts. You can have parts designated as subassembly parts without having a matching main/master part assigned. When you insert a symbol, you can just key in the assembly list value of a subassembly part you would like to add to this main/master part, on the fly.
Optionally, you can add multiple subassembly parts to this same main/master by entering a string of assembly list values separated by a semicolon. The default qty on the BOM will be 1 for each of these subassembly parts. For a qty of 2, add 2 and a comma to the beginning of an assembly list value. For example let's say you have a N.O. aux contact for a motor starter with an assembly list value of NOAUX, and N.C. aux contact with an assembly list value of NCAUX. You want 2 N.O. aux contacts and 2 N.C.contacts added to the BOM for a motor starter. Edit the motor starter coil symbol and key 2,NOAUX;2,NCAUX into the Assembly Code field. When you generate a BOM a quantity of 2 each of the aux contacts will appear below the part number for the starter.
Note that version 2015 will have no check boxes to designate main or sub.  You simply click the edit button in the Catalog Browser for a specific part number and enter the value directly into either the Assembly Code field, to designate a main/master or the Assembly List field, to designate a subassembly part.
Doug McAlexander
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
