Sathya,
If you go to the Project Manager and right click on your project you will
get a context menu. In that menu select Symbol Libraries... You will see a
dialog that looks like the attached dialog. Select the Panel radio button
and in the Panel Footprint Library entry you should have a path listed. The
path should point to where you can find the wd_default_terminal.dwg file.
By default that path is "c:/program files/autodesk/acade 2006/Libs/panel/".
Hope this helps.
Mike
wrote in message news:5089876@discussion.autodesk.com...
yes, pl find attached file which shows the paths
even I am getting the same kind of errors while inserting the PLCIO racks
info while creating the footprint for cabinet drawings
Is there any problem with the directory structure?
thanks in advance
