AutoCAD Electrical General Discussion
Valued Contributor
Masoome
Message 1 of 5 (779 Views)
Transferring symbol database from one PC to another
779 Views, 4 Replies
12-20-2010 04:51 AM
Hi every one,
I have built several symbols for my own usage; and also I have added some manufacturers (Pin list data base editor); and I have modified ICON MENU with new symbols (components) . Now, I should use another PC. It means I have a RAW program (Auto Cad Electrical). How can I transfer all those modifications to my new computer? Or I have to do all those again from the beginning?:smileysad:
Thanks and regards,
Masoome
Make sure that ACAD is NOT running on either machine to start off with.
Copy the blocks and default_cat.mdb (or whatever your catalogue is called) to the same locations on the new system.
I'm not sure on how to copy the icon menu but it may be as easy as copying the appropriate file across.
Regards Brad
Brad steered you in the right direction regarding the vendor part numbers.  If you have custom library symbols, you should copy the folder you stored those in.  The icon menu files are in the location shown below.  Of course substitute your name for mine in the path.  Your exact path is listed in the project properties for each of your projects under the Library and Icon Menu Paths section.  ACE_IEC_MENU.DAT contains the IEC menu and ACE_JIC_MENU.DAT contains the JIC menu.
Location of icon menu files: C:\Documents and Settings\Doug McAlexander\Application Data\Autodesk\AutoCAD Electrical 2011\R18.1\enu\Support
Hint: If you have created custom footprints and added entries into the footprint_Lookup.mdb, you should also copy this file to the other computer.
Icemanau
Message 2 of 5 (765 Views)
Re: Transferring symbol database from one PC to another
12-20-2010 04:04 PM in reply to: Masoome
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
dougmcalexander
Message 3 of 5 (750 Views)
12-21-2010 10:04 AM in reply to: Masoome
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Valued Contributor
Masoome
Message 4 of 5 (738 Views)
12-21-2010 10:21 PM in reply to: Masoome
Thanks a lot... That's it.
I did the instruction and it works properly.
Best
Member
sfcbatch94
Message 5 of 5 (305 Views)
08-23-2012 10:51 PM in reply to: dougmcalexander
Hi Doug,
Is there a way we can set the default saving location to drive D for icon menu files and database because I install deepfreeze on my drive c: every time I restart my pc, it goes back to its original state.
Eric John
Do on what you love to do... success comes next.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
