Are the blocks that are wrong, ones that have been made by someone in your
place of work?
Are they all from the same Library of blocks?
What version of ACADE are you using?
If the blocks are made by your company, you will need to open the block as a
dwg, rescale it to match the blocks installed out of the box
If you are using blocks from two different libraries, they will be scaled
differently for the various Libraries.
Have you changed the insert scale at the selection pallet, as that will
continue using the new scale you put in.
Regards Brad
wrote in message news:5990916@discussion.autodesk.com...
DIFFERENT DEVICES IN THE TOOL PALLET COME OUT AS DIFFERENT SCALES. SOME WILL
BE RIGHT AND SOME ARE A LOT SMALLER. HOW DO I GET THEM TO ALL BE OF THE SAME
SIZE OR SCALE.
