AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Today is ACADE day for me... Cables not wires...
2 REPLIES 2
warrenandy
535 Views, 2 Replies
As I ma not an electrical engineer or designer, I am not sure if this is a intended result or my users need more training. They want to place a cable, so they use the wire and then change it to a multiwire layer. Then when they run automatic numbering they do not want the wire to be labeled a s a wire. They want it labeled as a cable. But it auto numbers every time and shows up anyways. What is the proper procedure in this situation?
I am so rusty on ACADE I am not even sure if I am asking the right question, let me know if you need an example...
Andrew Warren
Manager, Engineering Services Support
Bridgestone Americas Tire Operations
warrenandy@bfusa.com
andywarrenbc@outlook.com
2 REPLIES 2
testsubject
in reply to: warrenandy
Andrew,
Your question is an easy one.
For multiwire cables, I created a new layer and called it "Cables". I then used "Create/Edit Wire Type" and added it as a wire type but set the "Wire Numbering" to equal "No". This way, the wires on this layer will do all the usual ACE function expect wire numbers.
I then add a Cable Marker to the wire bundle to designate the cable uniquely for Wire To/From Reports.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
andrew.warren
in reply to: testsubject
Thank you Bob!
Andy Warren
BCDesign@bellsouth.net
”Boost
