AutoCAD Electrical Forum
To adjust the line type scale.
4 REPLIES 4
ersidhu
523 Views, 4 Replies
To adjust the line type scale until dashed line types appear as fine or coarse as desire,Type
LSCALE
OR
LTSCALE.
PLZ HELP
Regards
ersidhu.
4 REPLIES 4
johnq
in reply to: ersidhu
Hi Ersidhu
I will try to help, I have been using ACE for about 18 months.
Your question seems ot indicate that you understand AutoCAD and use commands where I have used mostly used Icons.
In AutoCAD Electrical all commands are prefixed with AE.
I change line types and width etc in the layer tables.  It is the only way I know.  There may be a more elegant technique but I am not that educated.
Hope I am not telling you what you already know.
Cheers  john Quigley
dougmcalexander
The LTSCALE command can be typed at the command line as you mentioned.  The factor you set determines how coarse or fine the dashes appear.  This is a drawing-wide setting.  Once you are happy with the setting, you should set your template up the same way so all future drawings are preset with your desired line type scale.
Hint: This setting is most helpful to make sure dashed link lines between contacts and dash dot lines for location boxes appear clearly.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
ersidhu
in reply to: dougmcalexander
Thanks Sir,
You are great.
Thanks & Regards
ersidhu.
dougmcalexander
You are welcome.  Glad to help.
Doug McAlexander
”Boost
